RADDS Fan problem,
Hello guys! I have encountered a small problem with my Filament cooling fan, I have connected my fan to fan connector 2 on the radds board and trying to get it running? I got the fan menu on the screen but when I press 100% fan? and nothing happens? I have tried multiple options in the firmware still there is nothing?
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN ORIG_FAN_PIN
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 8
//#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define BLUETOOTH_BAUD  115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 160
#define YAXIS_STEPS_PER_MM 160
#define ZAXIS_STEPS_PER_MM 810.9182
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 204.952
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN      ///////ADDED 2
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_Z_ADD  2
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 110
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 195
#define MAXTEMP 260
#define FAN_KICKSTART_TIME  200
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER UICONFIG_CONTROLLER
  • #define FAN_BOARD_PIN ORIG_FAN_PIN
    sets the fan to default fan pin. That must match your difital arduino pin number of the output you use. Also make sure no other function is using that pin, espacially fan 2 as you have also set #define FEATURE_FAN2_CONTROL 1 enabling 2 fans (second would need M107 P1 S255 to start).
  • I have tried connect fan 1 in the first fan port to? but nothing happens?
    in know that the pins 9 8 is fan 1 and 2 i in the pins.h file ? so I should replace
    in Configuration.h From / To
    #define FAN_BOARD_PIN ORIG_FAN_PIN (TO)
    #define FAN_BOARD_PIN D8         (the same as the pin in the Pins.h file?)
    iv'e read that the secound fan port is the one used for printing cooling? (filament cooling) and not the first one?
    extruder cooler = 1   (Pin 9)
    Filament cooler = 2  (Pin 8)
    (Pins.h)
    #define ORIG_FAN_PIN   9
    #define ORIG_FAN2_PIN           8
  • I found the problem! :)
    EXTRUDER_FAN_COOL_TEMP was set at 50c
    That's why i got no response, so when i heated up the extruder it started spinning!!!! :)
  • I thought we were talking about filament cooling fan not extruder cooler:-) Extruder cooler goes only on when needed, that is correct.
