Change X, Y offset by GCODE
edited May 2016 in Extruder & Bed
Hello,
is there a posibility to change hotends offset (X and Y) by GCODE like M218 in Marlin or G10? I would like to do calibration gcode for dual extruder. Thanks :)
  • Yes, with M206 you can change all eeprom values. Best trick to learn the right parameters is enabling commands in log and edit using eeprom editor. Then you see which types/positions are needed for th eoffsets.
  • Nice - Thank you :) I will test it. Is this only one way to write value directly to EEPROM? For testing would be good something only temporary.
  • Yes it is the only solution. Host/server offer backing up your eeprom settings if you need to be able to go back.
