DRIVE_SYSTEM
I am trying to get a diamondhead to work with my mini kossel.  092
I go to the Wiki, get the diamondhead.h file, upload it to the configurator and make the changes...
It complies!!
Warning:  Low memory, instability yada yada
When I select Quick Settings ->  Home all   it just basically locks up.
Looking at an older config file, I see the difference is DRIVE_SYSTEM is set to 0.
In the new config, DRIVE_SYSTEM is set to 3.
When DRIVE_SYSTEM is set to 3, the steppers to not move.
When DRIVE_SYSTEM is set to 0, the steppers move.
Homing is an issue, though.   Let's say the head is all the way at the bottom - ~290mm,   homing will home one tower at a time, basically contorting the rods in a direction they don't really want to go.     How do I get all three motors to home at the same time?   I do not see a logical setting in the configurator for this?  At least not when I was looking at it.
Is there an all at once?
Thank you.
RAMPS 1.4
Full graphic display
  • You need DRIVE_SYSTEM 3. But deltas use much more memory so if output says free memory < 900 it is not enough and firmware can hang on some operations needing more stack ram.
    You need to reduce segments per line or move buffer lines. I'd prefer segements per line here as they are multiplied with move buffer lines. Reducing by 1 or 2 should suffice.
  • Cool, I will give it a shot.
    I had a working configuration at one point but lost it.
    FYI, here is the Ardunio build environment, verify compile result -
    Sketch uses 145,842 bytes (57%) of program storage space. Maximum is 253,952 bytes.
    Global variables use 7,654 bytes (93%) of dynamic memory, leaving 538 bytes for local variables. Maximum is 8,192 bytes.
    Low memory available, stability problems may occur.
    I will lower DELTASEGMENTS_PER_LINE  from 24 to 20 as a test.
    Sketch uses 145,832 bytes (57%) of program storage space. Maximum is 253,952 bytes.
    Global variables use 7,206 bytes (87%) of dynamic memory, leaving 986 bytes for local variables. Maximum is 8,192 bytes.
    Getting closer...
    DELTASEGMENTS_PER_LINE 18
    Sketch uses 145,734 bytes (57%) of program storage space. Maximum is 253,952 bytes.
    Global variables use 6,982 bytes (85%) of dynamic memory, leaving 1,210 bytes for local variables. Maximum is 8,192 bytes.
    1210, I'll go with this and report back in a few.
  • Still no movement.
    I went all the way to DELTASEGMENTS_PER_LINE 8
    No low memory, but still no motor movement and the screen stops.
    Changing from DRIVE_SYSTEM 3  to DRIVE_SYSTEM 0, motors move.
    DRIVE_SYSTEM 3  motors don't move.
    gong back to DELTASEGMENTS_PER_LINE  to 18, which puts me at 1210 bytes free, lower than the default of 24.
    Thank you for the help.
  • Here is my configuration.h   for a second set of eyes...
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       as you expect.
    #define NUM_EXTRUDER 3
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN HEATER_2_PIN
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    #undef X_MIN_PIN
    #define X_MIN_PIN -1
    #undef Y_MIN_PIN
    #define Y_MIN_PIN -1
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 1
    #define DRIVE_SYSTEM 3
    #define ZAXIS_STEPS_PER_MM 100
    #define PDM_FOR_EXTRUDER 1
    #define PDM_FOR_COOLER 1
    #define RETRACT_ON_PAUSE 5
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 96
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_START_FEEDRATE 0
    #define EXT0_HEAT_MANAGER 0
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_DECOUPLE_TEST_PERIOD 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 96
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
    #define EXT1_HEATER_PIN 11
    #define EXT1_INVERSE 1
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_MAX_START_FEEDRATE 0
    #define EXT1_HEAT_MANAGER 0
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define EXT2_X_OFFSET 0
    #define EXT2_Y_OFFSET 0
    #define EXT2_Z_OFFSET 0
    #define EXT2_STEPS_PER_MM 96
    #define EXT2_TEMPSENSOR_TYPE 1
    #define EXT2_TEMPSENSOR_PIN TEMP_0_PIN
    #define EXT2_HEATER_PIN 66
    #define EXT2_STEP_PIN ORIG_E2_STEP_PIN
    #define EXT2_DIR_PIN ORIG_E2_DIR_PIN
    #define EXT2_INVERSE 1
    #define EXT2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define EXT2_ENABLE_ON 0
    #define EXT2_MIRROR_STEPPER 0
    #define EXT2_STEP2_PIN ORIG_E2_STEP_PIN
    #define EXT2_DIR2_PIN ORIG_E2_DIR_PIN
    #define EXT2_INVERSE2 0
    #define EXT2_ENABLE2_PIN ORIG_E2_ENABLE_PIN
    #define EXT2_MAX_FEEDRATE 50
    #define EXT2_MAX_START_FEEDRATE 0
    #define EXT2_MAX_ACCELERATION 5000
    #define EXT2_HEAT_MANAGER 0
    #define EXT2_WATCHPERIOD 1
    #define EXT2_PID_INTEGRAL_DRIVE_MAX 230
    #define EXT2_PID_INTEGRAL_DRIVE_MIN 40
    #define EXT2_PID_PGAIN_OR_DEAD_TIME 7
    #define EXT2_PID_I 2
    #define EXT2_PID_D 40
    #define EXT2_PID_MAX 255
    #define EXT2_ADVANCE_K 0
    #define EXT2_ADVANCE_L 0
    #define EXT2_ADVANCE_BACKLASH_STEPS 0
    #define EXT2_WAIT_RETRACT_TEMP 150
    #define EXT2_WAIT_RETRACT_UNITS 0
    #define EXT2_SELECT_COMMANDS ""
    #define EXT2_DESELECT_COMMANDS ""
    #define EXT2_EXTRUDER_COOLER_PIN -1
    #define EXT2_EXTRUDER_COOLER_SPEED 255
    #define EXT2_DECOUPLE_TEST_PERIOD 12000
    #define EXT2_JAM_PIN -1
    #define EXT2_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 5
    #define RETRACTION_LONG_LENGTH 5
    #define RETRACTION_SPEED 50
    #define RETRACTION_Z_LIFT 0.3
    #define RETRACTION_UNDO_EXTRA_LONG_LENGTH 1
    #define FILAMENTCHANGE_Z_ADD  2
    #define FILAMENTCHANGE_REHOME 2
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 1
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_MAX_TEMP 150
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 297
    #define Y_MAX_LENGTH 210
    #define Z_MAX_LENGTH 323
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 217 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 150
    #define ROD_RADIUS 209.25
    #define PRINTER_RADIUS 209.25
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    //#define SOFTWARE_LEVELING
    #define DELTASEGMENTS_PER_PRINTLINE 8
    #define MAX_INACTIVE_TIME 600L
    #define MAX_FEEDRATE_X 350
    #define MAX_FEEDRATE_Y 350
    #define MAX_FEEDRATE_Z 350
    #define HOMING_FEEDRATE_X 200
    #define HOMING_FEEDRATE_Y 200
    #define HOMING_FEEDRATE_Z 200
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 0
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  -1
    #define SERVO1_NEUTRAL_POS  -1
    #define SERVO2_NEUTRAL_POS  -1
    #define SERVO3_NEUTRAL_POS  -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  200
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Diamonhead"
    #define UI_PRINTER_COMPANY "Homemade"
    #define UI_ANIMATION 1
    #define UI_SPEEDDEPENDENT_POSITIONING 1
    #define UI_AUTORETURN_TO_MENU_AFTER 120000
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 50
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   160
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_HEATED_BED_TEMP  30
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   250
    #define UI_SET_EXTRUDER_FEEDRATE 1
    #define UI_SET_EXTRUDER_RETRACT_DISTANCE 5
    #define NUM_MOTOR_DRIVERS 0
  • Have you chechekd eeprom values or copied from configuration.h
    M502
    M500
    Wrongly set data for delta paremeters like diagonal length.. can make strange things, otherwise I have no idea.
  • No I have not.
    It could very well be, moving between 2 different firmwares.
    I remember setting the 16 virtual extruders somewhere.
    Can you explain what you mean by copied from configuration.h ?
    I also got a hold of Cyan, Magenta, Yellow filaments..
    Currently trying to get this to work with the RAMPS 1.4.   A replacement Rumba board should be here tomorrow and am hoping that is an easier integration.    The add-on exturder motor board on the RAMPs works, but hard to keep the pins straight between all the different wiki notes and firmwares and google searches.
    This has to work, so many 3 color prints out there.
    It has to be EEPROM settings, I had a working configuration.h at one point with the single color head.  (of course I lost it)
  • COnfiguration.h settings re only copied to eeprom if you change EEPROM_MODE, so enabling new things after first initalization might have them uninitalized, e.g. starting with drive system 0 you have no copy of diagonal length.
  • It is working... Well, that is, it's moving.    I suspect I messed up the pins.h somehow.  That file is somewhat of a cluster.
    Closing this issue and moving on to next one, which is hardware related;  there appears to be a 'dip' of sorts in the middle of my print bed of ~1 - 2mm.
    Thanks!
  • Ack.  Got my bed level, back to messing with firmware.
    The printer prints but stops in the middle of printing.   Crashes, reboots.
    I have turned down delta segment settings very low but still free memory is only 500 bytes.
    How do I get more memory available?      Do I dump the graphic display?
    What is the best controller and board to use for delta and 3 extruders?
    I read somewhere that you no longer have a delta with an AVR,  what do you use?
  • //#define DELTASEGMENTS_PER_PRINTLINE 24  // original value
    #define DELTASEGMENTS_PER_PRINTLINE 8  // new value
    printer is working.
  • Ok, I see it was a memory problem then. I think 8 is a harsh reduction. If you compile you see free memory in ram whcih whould be 900-1000 byte for error free functioning. So maybe 17 would be a good value if your buffer count is 16.
    By 2 deltas use Arduino Due + RADDS board. This allows 300khz and 600 updates per second and ram increases from 8kb to 96kb, so no real problems here.
  • Hi,
    Buffer count is 16, happy to lower that.
    I am test compiling changing the number,
    At 11, the low memory warning starts to appear, leaving 1993 bytes free.  Each additional delta segment per line adds ~112 bytes.
    12 = 1881 bytes free
    13 = 1769 bytes free
    14 = 1667 bytes free
    15 = 1545 bytes free
    16 = 1433 bytes free
    17 = 1321 bytes free
    18 = 1209 bytes free
    19 = 1097 bytes free
    20 = 985 bytes free
    21 = 873 bytes free
    22 = 741 bytes free
    23 = 649 bytes free
    24 = 537 bytes free
    Maybe I can go as high as 19.
    What exactly is this line doing?   If you can sum it up in one sentence.
    Using the cheap full graphic display, changing configuration to the text display says 3%, if I recall.
    I am happy you said RADDS board, I ordered on a couple of weeks ago.
  • It is the buffer for moves to execute. You need some to prevent running out of moves when data sending is too slow for a second. Also you need some buffer for optimizing the speed profile. So 16 is what you normally want at least. With enough memory I like 32 but in your case 19-20 would also be better. You need 900-1000 byte free to run stable.
  • Thank you for the explanation.
    I push to 21 but now radds board arrives.
    Rep, what dislpay are you using?  I ordered a PanelDue.
