Diamond Head / Cyclops Hotend - Mixing Head Extruder > 1 Not Working
I have a mini Kossel, I am trying to get more than 1 color working and having problems.
Searching around, a lot of tips and tricks but nothing seems to work.
I did not want to hijack someone else's post.
I have RAMPS 1.4, Arduino Mega, forget the diamond head for now, I am trying to get the Cyclops head to work - 2 colors.
Using the web configurator. I believe this is 0.92 of Repetier firmware, how do I find out for sure?
The problem is that both extruder motors turn at the same time.
I've set heater pin -1 as mentioned in another post, this seems to have helped by making the motors do the same thing all the time.
In Marlin, I was able to set the extruder motor to use in Slic3r, but was never able to use both without the Z axis going wonky and plastic being extruded in air.
To me, it acts like it is in duplicate mode, or mirror mode but have never been able to let it run long enough because it is a mixing head and plastic goes everywhere.
Here is the relevant section of the configuration.h file...
#define MIXING_EXTRUDER 1
#define DRIVE_SYSTEM 3
#define ZAXIS_STEPS_PER_MM 100
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define KILL_IF_SENSOR_DEFECT 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 370
#define EXT1_TEMPSENSOR_TYPE 1
//#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_HEATER_PIN -1
#define EXT1_INVERSE 1
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_REHOME 2
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 0
#define PID_CONTROL_RANGE 8
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
