Diamond Head / Cyclops Hotend - Mixing Head Extruder > 1 Not Working
I have a mini Kossel,  I am trying to get more than 1 color working and having problems.
Searching around, a lot of tips and tricks but nothing seems to work.
I did not want to hijack someone else's post.
I have RAMPS 1.4, Arduino Mega, forget the diamond head for now, I am trying to get the Cyclops head to work - 2 colors.
Using the web configurator.   I believe this is 0.92 of Repetier firmware, how do I find out for sure?
The problem is that both extruder motors turn at the same time.
I've set heater pin -1 as mentioned in another post, this seems to have helped by making the motors do the same thing all the time.
In Marlin, I was able to set the extruder motor to use in Slic3r, but was never able to use both without the Z axis going wonky and plastic being extruded in air.
To me, it acts like it is in duplicate mode, or mirror mode but have never been able to let it run long enough because it is a mixing head and plastic goes everywhere.
Here is the relevant section of the configuration.h file...
#define MIXING_EXTRUDER 1
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 100
#define YAXIS_STEPS_PER_MM 100
#define ZAXIS_STEPS_PER_MM 100
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define KILL_IF_SENSOR_DEFECT 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 370
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
//#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_HEATER_PIN -1
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 1
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_Z_ADD  2
#define FILAMENTCHANGE_REHOME 2
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 0
#define PID_CONTROL_RANGE 8
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
  • Well, I found the version in the config file -
  • I have EEPROM disabled.
    #define EEPROM_MODE 0
  • I find a comment to another post, but do not understand the table or the concept of a virtual extruder, is this my problem?
    And I need EEPROM enabled?
    Text from other reply -
    Mixing extruder has been sucessfully used. Did you read
    your description sound slike you did not setup the mixing ratios in eeprom. Especially when upgrading with such new features you often end up with garbage and the default if it works is to have all extrude the same. Check what happens if one has 100% and other 0. If it still extudes 3x then you need to set it to 1/3. But I guess your ratios are set 0/0/0 so all do the same which does not happen with correct ratios.
  • OK this post seems to help me understand -
    Where is the EEPROM editor?
  • I don't get what this code is doing..
    M163 S0 P100
    M163 S1 P0
    M163 S2 P0
    M164 S0
    M163 S0 P0
    M163 S1 P100
    M163 S2 P0
    M164 S1
    M163 S0 P0
    M163 S1 P0
    M163 S2 P100
    M164 S2
    It looks like it sets each extruder with the same priority, then stores it?
    How do I use just Extruder0, or just Extruder1, or just Extruder2?
    I don't get the table.
    sorry for all the replies, trying to get to the bottom of this.
  • You need eeprom to store mixing ratios permanently.
    Read this to get started
  • Should the configuration.h file on that wiki page  compile as-is?  It does not.
    I upload it to the configurator linked in the article (092), make my edits (I have a Delta printer) and get different errors when compiling.
    As-Is generates this error:
    sketch\Extruder.cpp: In static member function 'static void Extruder::selectExtruderById(uint8_t)':
    Extruder.cpp:708: error: 'EXTRUDER_SWITCH_XY_SPEED' was not declared in this scope
             Printer::moveToReal(cx, cy, cz, IGNORE_COORDINATE, EXTRUDER_SWITCH_XY_SPEED);
    exit status 1
    With my modified configuration.h (uploading what is on the Wiki and changing printer type to Delta and some other settings), errors (too many to list), the configurator also shows 4 extruders when loading the file from the wiki
    In file included from sketch\HAL.h:83:0,
                     from sketch\Repetier.h:539,
                     from sketch\Extruder.cpp:22:
    sketch\Extruder.cpp: In static member function 'static void Extruder::initExtruder()':
    fastio.h:36: error: 'DIOORIG_E3_DIR_PIN_DDR' was not declared in this scope
     #define  _SET_OUTPUT(IO)  do {DIO ##  IO ## _DDR |=  MASK(DIO ## IO ## _PIN); } while (0)
    sketch\fastio.h:56:26: note: in expansion of macro '_SET_OUTPUT'
     #define  SET_OUTPUT(IO)  _SET_OUTPUT(IO)
    sketch\Extruder.cpp:533:5: note: in expansion of macro 'SET_OUTPUT'
         SET_OUTPUT(EXT3_DIR_PIN);
    fastio.h:36: error: 'DIOORIG_E3_DIR_PIN_PIN' was not declared in this scope
    etc...
  • No that file is expired. You need to upload it to config tool and download again with all added parameter. Tool will add missing parts automatically.
  • Got it.
