Moving Z when starting a print.
Hello,
I'm trying to modify my "old" Weistek WT200 printer to a "Repetier" printer. For that I bought a Arduino mega + Ramps 1.4.
So I started firmware configuration, my axis are correctly homed, step by mm is set, and extruder/thermistor work.
My Z axis is homed at the bottom of my printer, so I looking for the parameter where I can tell to my printer "move up to 140 mm" for the first layer of my print.
I do not have max Z sensor / auto-leveling system.
Thank you
