3D printers that run Repetier Software?
I am a 7th grade Technology who is interested in purchasing several 3D printers.  I have 8 Solidoodles currently that I am running Repetier Host with as well as Slicer.  Unfortunately Solidoodle is no longer in business.  I need to know what other 3D printers are available that I can run Repetier with.  I am trying to keep the cost under $750.  Thank you in advance! -Rich
  • In general all printers running Repetier-Firmware or Marlin should work fine. Most printers say which firmware they use and in these cases they even must provide sources of the installed firmware to comply to gpl.
