My extruder is running instead of my motors?? :/
I have hooked everything up fine on the motherboard, everything seems to be fine with the printer and the firmware as well and it compiles properly, etc. However, when I open Pronterface to manually control, home and all of that it starts moving the extruder for X, Y and Z movements instead of the X, Y and Z motors. Any idea why this would be?? Can't figure it out, any help on this would be greatly appreciated!
Warning:Invalid delta coordinate - move ignored
Error:No move in delta segment with > 1 segment. This should never happen and may cause a problem!
[ERROR] Error:No move in delta segment with > 1 segment. This should never happen and may cause a problem!
Does anyone have any idea what would cause this?
hardware based. The jumpers were not placed on my alternate Z motor
option so it was essentially an open circuit. When I placed my jumpers
side by side on the unused Z motor port everything worked fine.. Thank
you for your help however!
