Full Graphic Smart controller
HI
I have a problem.
First i had a problem thtat when i insert the sd card it says thrat the card is removed. then i have changed something in the firmware and have had a 14 hour print witch stoped on 92 % with a cant read sd error. after that i can not get the LCD to read the card. i need the lcd becouse if i have a long print the repetier host stops sending signals to the printer , communication error send buffer.
Can anybody help
thank you
I have a problem.
Can anybody help
thank you
and what could be the problem when in the middle of the print this errors comes out
Communication timeout - reset send buffer block
Cache size raised from 63 to 127 and right now using a 20cm insulated usb cable
no buffer errors
