PanelDue - no signal from board
Hello,
I have a problem with my paneldue running on atmel2560 board with the last version of repetier firmware (0.92.9). The panel is connected on TXD3 and RXD3 serial port of my board. With BLUETOOTH_SERIAL 3 and JSON_OUTPUT 1 the panel can drive the printer but don't receive any data from board like nozzle temp, files from SD...
I have do something wrong?
It shows that the printer is idle and can move the effector but cannot list the SD card contents.
It also only shows one of two hot ends and does not show current temperatures.
It can heat the bed but I have no idea if it's heating to the right temp.
I'm running a RAMBO 1.3 with Repetier .92.9. I have also tried the dev branch from github.
