Problems to get SD Card work.
Hello, I'm having some troubles to get SD card work with latest firmware.
I have set SDSupport to 1. Ui im using is RepRap Discount smart controller. I have hooked the SDRamps to Ramps1.4 correctly (checked it many times) but i won't get any confirmation that there is even SDSupport enabled when i start the printer. SD menu on LCd is empty, Repetier-host will send the commands when trying to mount SDcard but nothing happens. It wont even say that SD card init fail when i don't have sd card in reader. Where i should go looking for why/where SDsupport is disabled. I believe something is overriding Configuration.H sdsupport line..
