Extruder won't move (3 mixing Extruder)
It's my first post here so if I'm doing anything wrong..
So my problem is that none of the extruder won't move, I'm using Repetier FW and host.
All 3 extruder moves with MarlinFirmware. So I know all drivers and stepper motor works fine.
I have heated the extruder to 210c (min extrusion temp is 170c).
I also have tried the M302 (I got the message cold extrusion allowed).
I have used M502 & M500 to reset te EEPROM.
I don't get any errors or messages preventing the extrusion it only give me the Gcode expected.
And it is not in dry mode.
Well I hope someone will be able to help with that.
I've heated the hotend up to the correct temperature, enabled cold extrusion just in case.
Weirdly, if I reset the printer - both extruders work, but at the same time the Z-tower carriage starts sliding up. As soon as it hits the endstop, the extruders stop working again.
Have tried M502 and M500 and then setting the extruder parameters again to no avail.
Some help with that would be greatly appreciated.
