Add reprapdiscount full graphics smart controller support for RADDS board
I have add support for the reprapdiscount controller in combination with RADDS. I only changed ui.h for it.
In the online configure tool you can now select the full graphics smart controller ( 12 ) in combination with the RADDS.
And then it works
Is it possible to have these change integrated in the normal firmware release?
And then it works
I will post the converter on thingivers, free to user reproduce and sell.
I hope that is enough :-)
New version made tonight, I added 100% more witches. I made a couple slips when widening the holes with a pin vice, next time I'll give the CNC the proper bit and all the holes will be perfect.
I actually ordered from reprap.me, both the full graphics display and the arduino due (china clone). The RADDS (v1.5) I got from max3dshop. Just to try out, I fly-wired the display to both, RADDS and the Arduino Due directly. Comparing both configurations, the only difference is the levelshifter on the RADDS. Strangely enough, using RADDS I only see flashing random garbage on the display, while it works out-of-the box when connecting it directly in the same way (but without the level shifter) to the Arduino Due pins. My guess would have been that it may work with the Arduino Due if I/O voltage is luckily around 3.6v, but definitely works with RADDS.
However, it's exactly the inverse. Meanwhile, I also tried with a genuine Arduino Due with exactly the same result. Does anyone notice the same or have an idea what is going wrong here?
And did you had to change anything on the Repetier code or it was just enable that LCD mode in the configuration?
https://github.com/luc-github/DUE-RADDS-GLCD
I'm building a dremelbot with servo auto-probe that I'm hoping will make PCB's easier. drop an email to 3dprint352 at gmail com if you want to be notified.
