New to Repetier need help with Z probe height
I am new to Repetier been using MarlinKimbra.
Have a Prusa i3 with openbuilds extrusions. Trying v.92 and can't get the z probe height offset to work. I have an inductive probe, Ramps 1.4 I can get Z to home and it moves down some after homing but gap between the bed and extruder is .60mm.
I don't have a z min endstop, tried disabling that but then it doesn't probe, just moves down until the probe triggers and stops.
I can't do a G32 S2 thru Pronterface, comes back with unknown command G32 S2.
Just trying to find a firmware that autolevels properly
Connecting...
start
Printer is now online.
Info:External Reset
Minimum Speed:5.00
Minimum Speed Z:0.71
Setting bed temperature to 100.000000 degrees Celsius.
Setting hotend temperature to 245.000000 degrees Celsius.
zDistortionCorrection:0
Minimum Speed:5.00
Free RAM:3782
SelectExtruder:0
FlowMultiply:100
ok 0
TargetBed:100
ok 0
TargetExtr0:245
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
X:0.00 Y:0.00 Z:0.000 E:0.0000
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
ok 0
working on z height now
