New to Repetier need help with Z probe height
I am new to Repetier been using MarlinKimbra.
Have a Prusa i3 with openbuilds extrusions. Trying v.92 and can't get the z probe height offset to work. I have an inductive probe, Ramps 1.4 I can get Z to home and it moves down some after homing but gap between the bed and extruder is .60mm.
I don't have a z min endstop, tried disabling that but then it doesn't probe, just moves down until the probe triggers and stops.
I can't do a G32 S2 thru Pronterface, comes back with unknown command G32 S2.
Just trying to find a firmware that autolevels properly
  • Also WHY does this firmware keep echoing a OK 0 to the Pronterface console?
    Connecting...
    start
    Printer is now online.
    Info:External Reset
    Minimum Speed:5.00
    Minimum Speed Z:0.71
    Setting bed temperature to 100.000000 degrees Celsius.
    Setting hotend temperature to 245.000000 degrees Celsius.
    zDistortionCorrection:0
    Minimum Speed:5.00
    Free RAM:3782
    SelectExtruder:0
    FlowMultiply:100
    ok 0
    TargetBed:100
    ok 0
    TargetExtr0:245
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    X:0.00 Y:0.00 Z:0.000 E:0.0000
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
    ok 0
  • Figured out the G32 being an invalid command... I had FEATURE_AUTOLEVEL set to 0 !
    working on z height now
  • Z_PROBE_HEIGHT still not making a difference
  • here is the configuration.h probe section:
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_BED_DISTANCE 2
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 40
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 40
    #define Z_PROBE_XY_SPEED 600
    #define Z_PROBE_REPETITIONS 5
    #define Z_PROBE_HEIGHT .40
    #define Z_PROBE_REQUIRES_HEATING 1
    #define Z_PROBE_MIN_TEMPERATURE 230
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 10
    #define Z_PROBE_Y1 10
    #define Z_PROBE_X2 180
    #define Z_PROBE_Y2 10
    #define Z_PROBE_X3 10
    #define Z_PROBE_Y3 200
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
  • Did you get your Z Probe working?
  • Yes and no. I used Repetier host to edit the firmware offset for the extruder and got it to print. But I switched back to MarlinKimbra then to Marlin RC3 and had issues. MIght reload Repetier after doing a M502 and M500 to wipe the firmware
