CNC Mode Spindel control
I'm trying to use the M3 comment to start the spindel with the bead header output but it just starts for a fraction of a second and then stops.
If I set the temp of the headed bead it starts and continue to run, but in this mode it will time out on temp not going up for bead. (I think :-/ )
Dose any one have an idea what to do?
I have tried to:
- Run the M453 form the Repetier server console and then M3
- Run a file form SD with M453 and then M3 with and without the server attached
Running firmware 0.92.8
