CNC Mode Spindel control
edited March 2016 in Repetier-Firmware
I'm trying to use the M3 comment to start the spindel with the bead header output but it just starts for a fraction of a second and then stops.
If I set the temp of the headed bead it starts and continue to run, but in this mode it will time out on temp not going up for bead. (I think :-/ )
Dose any one have an idea what to do?
I have tried to:
  • Run the M453 form the Repetier server console and then M3
  • Run a file form SD with M453 and then M3 with and without the server attached
Running firmware 0.92.8
  • Sounds like you use the same output for your spindle and heated bed. That is not supported. The spindle needs a dedicated output for it's own or temp. control will always change output as you now see.
  • Thanks I will try to change the output in config.
  • That fixed it, I will just have to add a small relay to the output. I have some form a old project   ^:)^
