Ativate/deactivate Bluetooth from control pannel.
Hi, I've added a bluetooth adapter to my printer, but only use it to print from my laptop. Since it's connected to a 5V pin of the RAMPS, it's always on. I would like to have the option to activate/deactivate the BT adapter from the control panel.
I think it will be easy to achieve connecting the 5V input of the adapter to a free digital pin. Then we need a menu option to change the pin state: HIGH would turn the adapter ON and LOW would turn it off.
Thank you.
Thank you.
Thank you again!
