No extrusion from second extruder
Hello,
I have encountered a problem printing with the second extruder of my 3d printer:
When I want to print a part (with g-code generated by slic3er) using extruder 1, with support material using extruder 2, the printer only extrudes from extruder 1, all movements for extruder 2 are made, but no material is extruded. When I extrude manually, both extruders work fine.
When I write a small g-code-file myself, the print with both extruders also works.
Is there any setting (in slic3er or the firmware?) that could explain this problem?
Thanks,
robertalpha
Thanks,
robertalpha
In g-code, the commands for selecting the two extruders (T0 and T1) are at the correct positions, and the E parameters in print commands are also correct
I have found that the feed rates for extruder 2 are way to small, and started a new discussion in the slic3r category
Thank you so far
