Extruder Motor Not Working on Q3D OneUp V2
Hello, we recently got a Q3D OneUp V2 printer and have successfully put everything together. All of the motors work and the extruder heats up properly. Basically, everything works except for the motor that feeds the filament. We have made sure that dry run mode is disabled and we have tried swapping out that motor for one of the axis motor , and it functions properly, meaning that the program is not telling the extruder to run. We have tried connecting it to the E1 port, but do not know how to tell Repetier how to use that port for the extruder. If anybody has any idea as to what settings we need to change, please let us know because we have been working at this for about a month now. Thank you.
We have already made sure that the extruded is being heated to 200 degrees celsius and we believe we have already tried allowing cold extrusion, but could you explain further about the online confit tool? We do not have much experience with this.
