heating up bed: Command M140 SXX - heating fails after 1s; Command M190 SXX works properly
Since two month I am trying to figure out what could be wrong:
I am successfully running a little 3D-printer with repetier-Firmware and RepetierHost since more than two years by now. It has a Ramps1.4 and everything runs well seemless since ever.
Last year I started building a new printer - bigger, better, the usual... I decided to switch to Arduino Due with a RADDS addition. I want to use Repetier-Firmware on that printer as well, because I got used to it and I like it. I got everything running up to now. I can even print where really everything works fine - heating of bed and nozzle, steppers, etc.. Except when I try to preheat bed or extruder manually.
Heating the bed to 65°C for example transmitts the command M140 S65 to the Due. I can see the LED of the heated bed port turn on. But it turns off after one second. Sending the command manually responds in equal behaviour and I can not figure out what actually could be wrong.
Why does it heat up properly sending M190 S65 while sending M140 S65 sends it sleeping again after one second? I mean it is even printing...
Is it a known issue? Is there a solution. Did I set some safety function wrong? I compared it with the firmware of my old printer but I did not find any difference...
best regards,
Hanno
best regards,
Hanno
#define NUM_EXTRUDER 1
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#undef FAN2_PIN
#define FAN2_PIN -1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN ORIG_FAN2_PIN
#define FAN_THERMO_PIN -1
#define FAN_THERMO_MIN_PWM 64
#define FAN_THERMO_MAX_PWM 128
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 2
#define XAXIS_STEPS_PER_MM 320
#define YAXIS_STEPS_PER_MM 320
#define ZAXIS_STEPS_PER_MM 3200
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MIN_TEMP_RISE 0.5
#define KILL_IF_SENSOR_DEFECT 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 195
#define EXT0_TEMPSENSOR_TYPE 98
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_MAX_ACCELERATION 3000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 255
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 230
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
#define EXT0_EXTRUDER_COOLER_SPEED 127
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define USE_GENERIC_THERMISTORTABLE_2
#define GENERIC_THERM2_T0 25
#define GENERIC_THERM2_R0 100000
#define GENERIC_THERM2_BETA 4036
#define GENERIC_THERM2_MIN_TEMP -20
#define GENERIC_THERM2_MAX_TEMP 300
#define GENERIC_THERM2_R1 0
#define GENERIC_THERM2_R2 4700
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEAT_MANAGER 3
#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 180
#define HEATED_BED_PID_MAX 165
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 1
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN HEATER_0_PIN
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 250
#define Y_MAX_LENGTH 250
#define Z_MAX_LENGTH 250
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 1L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 5
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 3
#define DIRECTION_DELAY 3
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER 0
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 1
#define LANGUAGE_PT_ACTIVE 1
#define LANGUAGE_IT_ACTIVE 1
#define LANGUAGE_ES_ACTIVE 1
#define LANGUAGE_FI_ACTIVE 1
#define LANGUAGE_SE_ACTIVE 1
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 1
#define LANGUAGE_PL_ACTIVE 1
#define LANGUAGE_TR_ACTIVE 1
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define UI_SET_MAX_EXTRUDER_TEMP 260
#define NUM_MOTOR_DRIVERS 0
23:39:42.063 : wait
23:39:43.059 : N300 M105 *4
23:39:43.063 : ok 300
23:39:43.067 : T:26.58 /0 B:22.08 /0 B@:0 @:0
23:39:43.067 : Echo:N300 M105
23:39:44.065 : wait
23:39:44.771 : N301 M140 S65 *116
23:39:44.775 : ok 301
23:39:44.780 : TargetBed:65
23:39:44.780 : Echo:N301 M140 S65
23:39:45.779 : TargetExtr0:0
23:39:45.779 : TargetExtr1:0
23:39:45.779 : wait
23:39:46.159 : N302 M105 *6
23:39:46.162 : ok 302
23:39:46.168 : T:26.58 /0 B:22.08 /0 B@:0 @:0
23:39:46.168 : Echo:N302 M105
23:39:47.162 : wait
23:39:47.698 : N303 M140 S0 *69
23:39:47.702 : ok 303
23:39:47.702 : Echo:N303 M140 S0
23:39:48.331 : N304 M104 T0 S210 *5
23:39:48.338 : ok 304
23:39:48.339 : TargetExtr0:210
23:39:48.343 : Echo:N304 M104 T0 S210
23:39:49.260 : N305 M105 *1
23:39:49.264 : ok 305
23:39:49.268 : T:26.58 /210 B:22.08 /0 B@:0 @:230
23:39:49.269 : Echo:N305 M105
23:39:49.338 : TargetExtr0:0
23:39:49.338 : TargetExtr1:0
23:39:50.263 : wait
23:39:51.267 : wait
... some ideas?
I did not try the latest 92.8 from yesterday yet. But I will give it a shot. Did you hear about other people facing similar effects already?
I did the update to the latest version today with the same outcome.
I definitely have no dry switched on. I tried everything in "armed" mode. As I mentioned while printing it works seamless. I just printed stuff at the weekend. Two prints were longer than 5h, one took 3h. All worked well as expected. Just preheating the bed with comman M140 S60 fails as well as preheating the extruder with command M104 T0 S210.
wait
wait
wait
ok 0
TargetBed:60
TargetExtr0:0
TargetBed:0
wait
wait
wait
wait
wait
wait
ok 0
TargetBed:60
wait
TargetExtr0:0
TargetBed:0
wait
wait
wait
When the firmware states the TargetBed:60 i just sent the command (M140 S60). Then I receive one wait until the firmware resets the temperatures forbed and extruder to zero (--> TargetExtr:0 TargetBed:0).
I am already wondering if it could something in the configuration. But I doupt that because I looked through it so many times and there is nothing odd in there.
I followed the advice adding Com::printFLN(PSTR("Kill called")); to the Printer::kill function. Indeed the kill function was called quite frequent (around every µs). So I had a look into the configuration again and found a little timer setting in the mechanics section
Disable as much as possible after inactivity of
MAX_INACTIVE_TIME
Which was set to one second (i guess a preset value? Because I never touched it). Disabling it solved my problem. But I am not so sure if I like the result because everything stays powered now - stepper drivers, etc..
It was set to one second in myold printer as well. Interesting is that heated bed and extruder keep heating although everything else stays cold - especially the stepper drivers.
Has there been some changes in this part of the firmware lately?
