heating up bed: Command M140 SXX - heating fails after 1s; Command M190 SXX works properly
Since two month I am trying to figure out what could be wrong:
I am successfully running a little 3D-printer with repetier-Firmware and RepetierHost since more than two years by now. It has a Ramps1.4 and everything runs well seemless since ever.
Last year I started building a new printer - bigger, better, the usual... I decided to switch to Arduino Due with a RADDS addition. I want to use Repetier-Firmware on that printer as well, because I got used to it and I like it. I got everything running up to now. I can even print where really everything works fine - heating of bed and nozzle, steppers, etc.. Except when I try to preheat bed or extruder manually.
Heating the bed to 65°C for example transmitts the command M140 S65 to the Due. I can see the LED of the heated bed port turn on. But it turns off after one second. Sending the command manually responds in equal behaviour and I can not figure out what actually could be wrong.
Why does it heat up properly sending M190 S65 while sending M140 S65 sends it sleeping again after one second? I mean it is even printing...
Is it a known issue? Is there a solution. Did I set some safety function wrong? I compared it with the firmware of my old printer but I did not find any difference...
best regards,
Hanno
  • Alright I guess it maybe makes sense to post my configuration:
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #undef FAN2_PIN
        #define FAN2_PIN -1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN ORIG_FAN2_PIN
    #define FAN_THERMO_PIN -1
    #define FAN_THERMO_MIN_PWM 64
    #define FAN_THERMO_MAX_PWM 128
    // Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
    // If it is incompatible you will get compiler errors about write functions not beeing compatible!
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 2
    #define XAXIS_STEPS_PER_MM 320
    #define YAXIS_STEPS_PER_MM 320
    #define ZAXIS_STEPS_PER_MM 3200
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MIN_TEMP_RISE 0.5
    #define KILL_IF_SENSOR_DEFECT 1
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 195
    #define EXT0_TEMPSENSOR_TYPE 98
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_ACCELERATION 3000
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_INTEGRAL_DRIVE_MAX 255
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 230
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
    #define EXT0_EXTRUDER_COOLER_SPEED 127
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define USE_GENERIC_THERMISTORTABLE_2
    #define GENERIC_THERM2_T0 25
    #define GENERIC_THERM2_R0 100000
    #define GENERIC_THERM2_BETA 4036
    #define GENERIC_THERM2_MIN_TEMP -20
    #define GENERIC_THERM2_MAX_TEMP 300
    #define GENERIC_THERM2_R1 0
    #define GENERIC_THERM2_R2 4700
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_HEAT_MANAGER 3
    #define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 180
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define HEATED_BED_PID_MAX 165
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 1
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN HEATER_0_PIN
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 1
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 250
    #define Y_MAX_LENGTH 250
    #define Z_MAX_LENGTH 250
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 1L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 5
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_XYZ
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 3
    #define DIRECTION_DELAY 3
    #define STEP_DOUBLER_FREQUENCY 80000
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_FAN2_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 1
    #define LANGUAGE_SE_ACTIVE 1
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 1
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  • I saved the log of switching on first the bed then EXT0 (the first extruder)
    23:39:42.063 : wait
    23:39:43.059 : N300 M105 *4
    23:39:43.063 : ok 300
    23:39:43.067 : T:26.58 /0 B:22.08 /0 B@:0 @:0
    23:39:43.067 : Echo:N300 M105
    23:39:44.065 : wait
    23:39:44.771 : N301 M140 S65 *116
    23:39:44.775 : ok 301
    23:39:44.780 : TargetBed:65
    23:39:44.780 : Echo:N301 M140  S65
    23:39:45.779 : TargetExtr0:0
    23:39:45.779 : TargetExtr1:0
    23:39:45.779 : wait
    23:39:46.159 : N302 M105 *6
    23:39:46.162 : ok 302
    23:39:46.168 : T:26.58 /0 B:22.08 /0 B@:0 @:0
    23:39:46.168 : Echo:N302 M105
    23:39:47.162 : wait
    23:39:47.698 : N303 M140 S0 *69
    23:39:47.702 : ok 303
    23:39:47.702 : Echo:N303 M140  S0
    23:39:48.331 : N304 M104 T0 S210 *5
    23:39:48.338 : ok 304
    23:39:48.339 : TargetExtr0:210
    23:39:48.343 : Echo:N304 M104 T0  S210
    23:39:49.260 : N305 M105 *1
    23:39:49.264 : ok 305
    23:39:49.268 : T:26.58 /210 B:22.08 /0 B@:0 @:230
    23:39:49.269 : Echo:N305 M105
    23:39:49.338 : TargetExtr0:0
    23:39:49.338 : TargetExtr1:0
    23:39:50.263 : wait
    23:39:51.267 : wait
    ... some ideas?
  • Did you send the disable bed after 3 seconds? Maybe a few more seconds would be good to see M105 evolve, but on first look it looks like it had bed already tuned of also you see clearly that it was set to 65 as expected. That is strange as there is no indication that it was reset to 0.
    Have you tried latest 92.8 from yesterday? There was a problem with bed in combination with thermo coupled fan, whcih you do not have, but you never know.
  • I did not send the bed disable after 3 seconds. I just sent M140 S65 manually. It seems that the firmware itself decides to turn the bed off again. I am running a DUE with RADDS. I am already wondering if it is maybe an issue with the DUE trunk of the repetier firmware. I am facing the problem since 92.6 what was the versionof the firmware when I started trying this.
    I did not try the latest 92.8 from yesterday yet. But I will give it a shot. Did you hear about other people facing similar effects already?
  • 23:39:47.698 : N303 M140 S0 *69
    that is a command coming from your host which I assumed you send. As you see it disables the bed. What host are you using? Looks a bit like repetier and that command gets send if you hit the bed button.
    No you are the only one where the bed goes off directly.
  • Indeed I am using repetier host. When I input the command manually it shows the same behaviour. Is there a setting in repetier host which I missed? Or could it be an issue with my linux host?
  • The host never changes temperatures on it's own. You need always to hit the button or move slider to get it disable. So unless you use double clicks to enable I see not how this should happen and sending manually would also not effected by the problem. Do you really always see the disable command followed within a few seconds?
  • No, I enable the heating and the controller disables by itself. Neither me nor the host sends a disable command. And that is the odd part. It seems that the firmware disables the heaters after a second.
    I did the update to the latest version today with the same outcome.
  • I just rechecked the code. M1040 and M190 are the same except M190 does wait afterwards and there it seems to work.
    Other reasons to disable bed (which would also disable extruders) would be activating dry rund and stepper timeout. But these would also work on M190.
  • I also checked that and did not see any difference btween m140 and m190 except the waiting time. Maybe i recheck it this evening. I am going to have a look if it could have something to do with code it executes after executing m140. And I will try to send the command from a plain terminal to see if it is a host problem.
    I definitely have no dry switched on. I tried everything in "armed" mode. As I mentioned while printing it works seamless. I just printed stuff at the weekend. Two prints were longer than 5h, one took 3h. All worked well as expected. Just preheating the bed with comman M140 S60 fails as well as preheating the extruder with command M104 T0 S210.
  • That is in deed not understandable as I change bed temperature all the time with that command und thousands of other users do all without problems.
  • I connected with CuteCom (Terminal under Linux) and logged the following:
    wait
    wait
    wait
    ok 0
    TargetBed:60
    TargetExtr0:0
    TargetBed:0
    wait
    wait
    wait
    wait
    wait
    wait
    ok 0
    TargetBed:60
    wait
    TargetExtr0:0
    TargetBed:0
    wait
    wait
    wait
    When the firmware states the TargetBed:60 i just sent the command (M140 S60). Then I receive one wait until the firmware resets the temperatures forbed and extruder to zero (--> TargetExtr:0 TargetBed:0).
    I am already wondering if it could something in the configuration. But I doupt that because I looked through it so many times and there is nothing odd in there.
  • What I see is that bed and extruder get new values. So it is not just be dtemperature being reset I guess. In your case I'd add
    Com::printFLN(PSTR("Kill called"));
    to Printer::kill function, maybe even with parameter send (must be cast to int with (int) so yous ee if it is the kill function restting it. That is the only function that can do it and gets called automatically on some timeouts. Also check your timeouts in eeprom.
  • edited February 2016
    Neat! Thanks for your help! I solved it!
    I followed the advice adding Com::printFLN(PSTR("Kill called")); to the Printer::kill function. Indeed the kill function was called quite frequent (around every µs). So I had a look into the configuration again and found a little timer setting in the mechanics section
    Disable as much as possible after inactivity of
    MAX_INACTIVE_TIME
    Which was set to one second (i guess a preset value? Because I never touched it). Disabling it solved my problem. But I am not so sure if I like the result because everything stays powered now - stepper drivers, etc..
    It was set to one second in myold printer as well. Interesting is that heated bed and extruder keep heating although everything else stays cold - especially the stepper drivers.
    Has there been some changes in this part of the firmware lately?
  • Maybe it is an idea to add some options for parts which should not be disabled after the timeout, like heatings...
  • Default is 0 and disabling stepper after 5 minutes of inactivity. So we have the difference and heaters stay normally on steppers not. But thats up to user.
