Bed auto leveling and -2.1mm offset
I use Repetier Firmware 0.92 on my XYZ da Vinci 1.0A. I just have successfully run the auto calibration and got the following results:
Z 1: -1,839 mm
Z 2: -1,840 mm
Z 3: -1,848 mm
I tried to print a quick example but had to do an "Emergency Stop" because the nozzle was hitting the bed. So I checked the offset and it was 2.10 mm (to the correct bed Z position).
I do not want to configure this offset with e.g. Repetier-Host or other software. To clarify misunderstandings: I had to lower the bed for 2.10 mm.
Which setting (firmware side) do I have to adjust in order to get correct results when printing with 0 offset (software side)?
