I've spent an hour looking through the documentation, but alas, I can not find any info. How difficult would it be for a novice programmer to accomplish this? What entries do i need to change?
This is more a firmware related question. Our software only works with step/dir so if you can program a layer to map this to motor cotrol and modify code where steps are done it can be done, but I have no experience with these motors so can not say how hard it is to accomplish this.
It is possible to have both BLDC and AC servo motors, but they have different uses. AC servo motors provide high torque and precise control for industrial automation, whereas BLDC motors are dependable, effective, and frequently utilized in electric vehicles and robotics. Your decision is based on the needs of the application, such as torque, speed, and control complexity.
completely understand the frustration of searching through documentation without finding clear answers. Buy essay onlineservices remind me of when I struggled with a coding project and needed expert guidance to save time. I once spent hours trying to tweak entries in a config file, only to realize later that a small syntax error was holding me back.
