Printer comes up as a different make and model
I have recently installed repetier and converted my Da Vinci 1.0A printer to use third party software. Everything works fine up until when my printer is connected; for some reason on repetier host, my printer comes up as “Mendel” which is not the model printer I am using; not even the same maker. I believe this is also the reason why my bed will not heat up, even after some manual g-code to do so, and also my bed will only move down, even if given vertical input. I am not certain why this is, but I believe that it is because the software is seeing my printer as a different one, which does not have a moveable bed, nor a heated one. Can anyone help me solve this issue?
Which firmware did you use? The da vinci form from Luc with predefined configurations?
Means bed is set to 55 and heating 100%. If this is longer in that state and still 20deg measured it is a problem in firmware using wrong pin number for heater output assuming hardware is ok and powered. Most boards also have a led on heater output so you see if that output is enabled.
is the version adjusted for some davinci printers.
