issue using config tool either 92 or 1.0
used the Config tool keep getting errors during compile with either tool says problem temp pin 3 which is an easy fix i have 3 extruders should be temp 1 heater o
but for some reason thoughts pin 3 in on ext 2 but after fixing that
also i download the complete file and start with Repetier ino
tried going back to an earlier config H, but still wont Compile verify can get past this and wont go past ?
Also Wondering what this junk is from zzzzzzzzzzzzzzzzzzzzzzzz seen during the error report below?
This is only part of a very long error list but this is the tail end.
#define EXT2_ENABLE_PIN ORIG_E2_ENABLE_PIN
C:\Users\recou\Desktop\Ramps 2\Repetier-Firmware-2024-03-23\Repetier-Firmware\Repetier\Extruder.cpp:3205:74: note: in expansion of macro 'EXT2_ENABLE_PIN'
{ 2, EXT2_X_OFFSET, EXT2_Y_OFFSET, EXT2_Z_OFFSET, EXT2_STEPS_PER_MM, EXT2_ENABLE_PIN, EXT2_ENABLE_ON, EXT2_MAX_FEEDRATE, EXT2_MAX_ACCELERATION, EXT2_MAX_START_FEEDRATE, 0, EXT2_WATCHPERIOD, EXT2_WAIT_RETRACT_TEMP, EXT2_WAIT_RETRACT_UNITS
exit status 1
Compilation error: 'DIOORIG_E2_DIR_PIN_DDR' was not declared in this scope
EXT0_TEMPSENSOR_TYPE 1
#define EXT2_DIR_PIN ORIG_E2_DIR_PIN
errors-------------------------------------------------
recoush
With SHARED_EXTRUDER enabled same heater/sensor is good.
