New 10 year old Zeepro Zim fillement feed motor(s) not working or getting commands?
Hello I just aquired a NEW 10 year old Zeepro Zim dual head 3D printer.. I have successfully ran a 1st print all except the feed isn't operational so fillement isn't getting to the heated head(s) is there a feed rate that I am to enter? I made sure cartrige was loaded correctly and even softtened the brittle spool in the oven tried 2cnd print and I am not seeing any movement at the feed stepper motor(s) ? any suggestions? Everything else looks to be in working order.
With enough knowledge you can change electronics on all printers, ist just a lot of work and you must know what sensors etc you have and compile a own firmware. Just like with any self build printer. Decide for a firmware ans see if which board is supported that has enough drivers/inputs for your solution.
