Z goes too up after homing
Greetings!
I got my first 3D printer recently, and I tried to make it work. It's a GeeeTech I3.
My issue is, when I'm homing all the axis, they work perfectly. I configured the Z axis to be just high enough above the bed to be able to let a paper sheet goes between them.
But when I'm starting to print - I'm using Slic3r -, the axis gets homed, and when the Z axis touch its "stop" button... It proceed to go ~5mm too much above the bed. What can I do? I tried to change the Z offset from the Slic3r printer menu, but nothing changes (I did put -5)
Thank you in advance for your help!
If you need more informations, tell me!
Best regards,
Shero
![:) :)](/resources/emoji/smile.png)
Best regards,
Shero
G28
M119
has nozzle at good position and in console you see z = 0 then firmware should be ok. If not firmware/printer is probably not configured correctly.
So next would be to check the generated g-code on z moves. Actually it is not common that nozzle goes up after homing to heat it. On bed it can melt the bed so it is a good thing to lift it until hot and then go down for printing.
Thank you for your answer!
I found the solution. The homing system works so when the "wagon" touches a button, it knows its position is 0.
The thing is, the printer set the position Z on 0 when the button is pushed.
Slic3r set the position Z on 0 when the button is released.
I just had to ajust the screw that pushed the so called button... And now it works! Not flowlessly (beginner 101 ^-^'), but i'll learn from there.
Happy printing!
Best regards,
Shero
