Z goes too up after homing
Greetings!
I got my first 3D printer recently, and I tried to make it work. It's a GeeeTech I3.
My issue is, when I'm homing all the axis, they work perfectly. I configured the Z axis to be just high enough above the bed to be able to let a paper sheet goes between them.
But when I'm starting to print - I'm using Slic3r -, the axis gets homed, and when the Z axis touch its "stop" button... It proceed to go ~5mm too much above the bed. What can I do? I tried to change the Z offset from the Slic3r printer menu, but nothing changes (I did put -5)
Thank you in advance for your help!
If you need more informations, tell me!
Best regards,
Shero
Best regards,
Shero
G28
M119
has nozzle at good position and in console you see z = 0 then firmware should be ok. If not firmware/printer is probably not configured correctly.
So next would be to check the generated g-code on z moves. Actually it is not common that nozzle goes up after homing to heat it. On bed it can melt the bed so it is a good thing to lift it until hot and then go down for printing.
Thank you for your answer!
I found the solution. The homing system works so when the "wagon" touches a button, it knows its position is 0.
The thing is, the printer set the position Z on 0 when the button is pushed.
Slic3r set the position Z on 0 when the button is released.
I just had to ajust the screw that pushed the so called button... And now it works! Not flowlessly (beginner 101 ^-^'), but i'll learn from there.
Happy printing!
Best regards,
Shero
