Configuration.h location?
Hi, I want to use the original Repetier software for my Fischertechnik 3d printer with a modified Extruder. I want to copy the old Configuration.h from the "3d print control" App (which is based on your software) over to yours. Where is the Configuration.h file from Repetier Host? And is it enough to just copy this file, or will there be other settings to change?
Regards Elias
Regards Elias
There was in deed a fiser technic version of our host, but never had a fisher technic printer so never used it. If there are slicer configs, these are just folders and you can copy them. On the other side, new host has the much better PrusaSlicer included which Ithink was not included in that version and switching to it might be a better idea. App settings are mainly what you see in printer config. Just run both in parallel and copy them to new app. There is no file with these - that stuff is in windows registry.
Thanks and sorry for my cluelessnes
M303 P<extruder/bed> S<printTemerature> X0 R<Repetitions> C<method>- Auto
You might want to reduce pid drive max to 128 so it does not use full power. Giving it so much more energy will increase overshoot, so select a target temperature that is well below your max. temperature. Say 180 so with 60 overshoot you are still within limits.
X0 and methods 3-4 will likely not work as they were added later I think.
M303 E0 S200 C8
What command should I try exactly?
Thank you very much for your fast replies btw
M303 E0 S140 C8
and it said "Error: PID Autotune failed! Temperature too high"
the temperature then rised quite slowly to 198 degrees and is going back now.
Ich merke gerade, dass ihr Unternehmen aus Deutschland kommt...
C8 gibt es nicht nur 0-2
Viel erfolg mit dem tweaken.
