Ramps 1.4 3D Touch
Hi, I wanted to add 3DTouch to the Rebel 2, but after changing the firmware and connection, the printer still says Z min limit switch off.
Here is configuration.h https://docs.google.com/document/d/1MloSmkFmi9EDtuBYG1uk6yWeDF2bP625OpvRPhacdVM/edit?usp=sharing
  • Switch is nearly always low. When triggered it only stays high for a few ms. I think only in alarm state it is longer high. So for testing (G30) move up high and trigger it by hand to have enough time if it does not detect it.
