Backup the Firmware from printer
Hi Guys,
I recently got myself a Tripodmaker Black Edition V3, and after some tinkering got it printing rather well. The only problems I have now is with the temp control, because the values are 10 degrees to low. So I think I need to flash the firmware. Before proceeding it seems a good idea to backup the existing firmware, but I'm not sure how to do this, and if it's possible. Is there anyone here who can point me in the right direction?
Some bootloaders can backup data others not. Then you need special hardware to backup and need to hope there is a connector for the programming hardware. Especially with 32 bit boards this is often not the case since upload via sd card or using dfu is always possible.
Easiest solution would be if you can download firmware from printer manufacturer website as backup.
but there is no override. This would be dangerous if you can just state to get higher then extruder can handle. So sorry, needs to recompile firmware for this.
