Repetier + Klipper connect manual???
I am using repetier server.
I recently experienced voron+klipper+mainsail.
The mainsail and Klipper installation manuals made it easy for beginners to follow.
Also, I felt that the klipper was much stronger than Marlin.
However, in UX, no one can follow Repetier.
I want to use Klipper and Repetier together.
Is there a separate manual for installation?
* According to the klipper manual, install klipper via mainsail, fluidd, or octoprint I'm not sure, but it seems I can't install only the klipper firmware.
Use our pi image and select wizard installation, select klipper as firmware and then tell server to install klipper. Then you have a unconfigured but working klipper. Select klipper from printer menu und copy your printer config and you are done if you choosed same klipper version for install. Otherwise you might need to install firmware stub on voron board, but in the klipper page you can compile that easily. In manual is a klipper entry with more details. Assuming latest server version which has best klipper support.
https://www.repetier-server.com/manuals/1.4/index.html
the chapter Advanced Themes->Klipper
which shows installation details. But you also need to know how to write klipper configuration file. We only describe installation, the konfiguration of klipper config is described on klipper homepage.
I you have a detailed question let me know where exactly you have a problem with understanding.
1. As in the manual, in [Printer configuration wizard], select klipper for firmware and install it.
6. Printer power off
9. Unable to connect.
1. Printer with board
2. Klipper
3. Repetier-Server
So you need to figure out which component is making troubles. On server side if you see a green link you are talking with the klipper and know it is not 3. You might see a yellow warning icon next to green link. Click it and you get more information why it failed on 1-2. In newer versions you can also select to show end of klipper log to see if there is something.
I think uploading firmware it self worked so far when you downloaded the generated bin file. That is how I update my skr e3 mini as well.
Now thinks often get wrong:
- Wrong serial port in klipper configuration
- Includes in printer configuration. The folder the config is stored has no configs and mainsail might have some extra files you included. Replace include with content or hit save as for your config to add a new file to folder, name it as your include file and put content in it, then you can include it as well.
- Some other config errors, but when it worked on mainsail I think it is one of first two here.
Sounds like server-Klipper connection is working good now, but klipper->Printer board is the problem now. Did you already upload the klipper firmware stub to the mini? If so the issue is a bad klipper configuration which is the equivalent of the marlin config.h file. See klipper log end in server for more informations where your exact problem lies. Save and install will restart klipper with new config file and generates new log entries. Maybe it is just the serial name you enter in the config that is wrong. If you have only one printer connected you see it with
ls -l /dev/serial/by-id
and you enter /dev/serial/by-id/<name from ls>
that should make klipper connect with board at least.
adxl works but you need to install input shaping or the pi klipper service for it does not run.
What is this pause/cancel code? We have gcodes in printer configuration in case you mean regular gcode commands.
