Due + RADDS external SD
Hello,
Using a RADDS shield and an arduino Due and I am trying to connect and configure an external SD module for use with Repetier firmware 0.91.4.
I am relatively sure I have it wired up properly:
But I am not sure what changes I need to make to repetier firmware to use the SD module.
Original Post for more details about what I have tried already
https://groups.google.com/forum/#!topic/deltabot/ojmM0SZcoMo
#define SDSS 10
#undef SPI_PIN
#define SPI_PIN 77
#undef SPI_CHAN
#define SPI_CHAN 0
At the end of pins.h you see the 4 possible pins and according channels.
No echo for variables.
Hi
You could also consider to by the LCD unit for the RADDS, it has I cardreader built-in.
