MKS Gen L 2,1
Has any one or does anyone Know how to configure MKS GEn L 2.1 to work with Repetier?
my understanding was it should be a successfully replace Ramps 1.4 but all of thesoe changes in Marlin,
Don't see how to incorporate the motherboard change from ramps 1.4 to MKS gen L 2.1 for Repetier
anyone have any ideas on this or am i stuck having to switch to Marlin, might have to switch to some other board ?
I know they are very similar any potential issues having to change Pins etc..
Repetier-Firmware configuration tool for version 1.0.4 .
And used Ardiuno to load into firmware..Seem to me that I just used the standard items that came up.?
"RAMPS 1.3/1.4" and just picked the actual display
started installing new drivers since the old ones are 5 years old keeping for spares.
need to hook up some motors and extruders and see how works then i can swap out the old ramps 1.4
So far, off to a good start.
Thank you EinarSkog and Repetier
I am waiting to update the cpu until after making some more adjustments due to some minor glitches with my replacement ramps 1.4 the old one was 5 years old so verifying operational before further upgrades :>)
