WHile you can select which image to use with eye icon, you can not change rendering angle. This is set for all prerendered gcodes and stl files to values working in general. I see that it might be nice in this example to have higher view point, but you won't want to set it for every upload.
Thanks. Unfortunately I have almost 2000 models with this "problem". It would be nice to be able to change the viewing angle.
Is there any news about this "feature"?
To clarify:
- I create a new object
- I upload a jpeg file, the relative
stl file and the gcode file.
This is the preview I see if I set the jpeg file.
In global settings->Preview images you can define in which direction the camera is. New files get new rendering. When it is ok you can there also trigger recomuting all files which can take long so wait until settings are good.
