Project preview
Is it possible to change the preview of a project? I wish he had a different inclination.
For esxample:  this is original
Immagine-2022-08-26-201740" I wish it were so, otherwise it is hardly understandable: Immagine-2022-08-26-201810
  • WHile you can select which image to use with eye icon, you can not change rendering angle. This is set for all prerendered gcodes and stl files to values working in general. I see that it might be nice in this example to have higher view point, but you won't want to set it for every upload.
  • edited August 27
     Thanks. Unfortunately I have almost 2000 models with this "problem". It would be nice to be able to change the viewing angle.
