Does Repetier Host work with Rock64
Does Repetier Host work with Rock64? Did anyone test this before and what was the stability and install process like?
  • It is preconfigured for intel cpu, not arm. Bette ruse  Repetier-Server on such a board as it is designed for low cpu usage/resources and is also available as 64 bit arm version.
