Just bought an XYZ Davinci 2.0a With Repetier - HELP please lol
Hi, I'm pretty computer savvy and have programmed Arduino's before, so not a complete noob.... but...
I recently bought a Davinci 2.0a which has already been flashed with 0.92.10M
The second extruder isn't registering and when it does a print, it's REALLY fast but the resulting model just falls apart when you take it off the bed, so I'm guessing the configuration was a bit off. As well as the bed size is wrong lol.
I'm struggling to find the correct settings and trying the online configurator, I have no idea what I need to be selecting for Processor (i think it's mega) Motherboard (literally no idea lol) Printer type, or EEprom usage.
Most other things I can probably figure out with trial and error, but if anyone can help me with the basics, or even has a working config I can use, then that would be awesome.
Any help is much appreciated!
Dave.
Dave.
Normally you can change settings like steps per mm in eeprom without any need to recompile firmware. Just call the eeprom editor in Repetier-Server or Repetier-Host.
Thank you for your help.
I am new using the version of repeater adapted to Da Vinci printers. I installed it in a first generation duo with second generation extruders.
But you have presented the problem when start to print the left extruder temperature sensor stops working and signals a fatal error. It does that even if I give it the instruction to auto level the bed or try to do it manually.
Do you know what the problem could be or how I can solve the problem?
It is worth mentioning that if I load filament in either of the two extruders it does it very well, loading and unloading.
All the best
