PLA and ABA heated always selected
I have an XYZ davinci converted to PLA and running repetier 0.92. Under Maintenance, the PreHeat PLA and ABA and Cooling down are always selected. I've tried repowering. I've tried holding the ok / Home buttons as I power on. I've tried removing the SD card and putting that back again. I'm stuck. Help would be appreciated, thank you.
https://drive.google.com/file/d/1OnSIslerxOG4EGJZPjtydC60VlBXfBh6/view?usp=sharing
So I can not really say what is going on here. Maybe on the github issue tracker you have someone using it that knows the issue.
You might also try to connect to Repetier-Server and see what is going on in console. Maybe there is a message like could not init sd card.
You also say the actual stl shows not up - hope that was an error as you can not print stl files:-) You only print converted gcode files.
I would also try a new fat formatted sd card in case it is an error on sd card that makes the problems. Users were using this a lot as far as I hear questions about it, so it must have been working.
Now, preheating is unselected and there is an option to print file. And yes, I'm printing stl as that's what the previous owner printed.
So now I turn on the printer and select preheat PLA. That done, click the Print File command and SD Paused flashes and I'm instructed to load filament. I have, but it is not being sensed.
I click Load Filament and the extruder heats up and beeps at the correct temp, 213. I run the filament through the extruder and back out of that command to Home. The Print File command had gone!
Restart, reboot, round and round in circles. I cannot get to print anything.
BTW: You know you can print without sd card as well? With Repetier-Server run on a device of your choice you can print from that via usb connection.
Since it is a heavy modified firmware I can not say what changed. Maybe it has the gcode filter enabled only showing gcode files and since yours is names .stl it has wrong ending. Would be th eonly thing I could think of that might cause empty print list.
Also, what does 'SD Paused' mean please and how do I fix that?
