how to connect the Esp32 wifi to the connect ramps 1.4 ?
hello, I have connected the ESP32-38 PIN, to the ramps 1.4 instead of the bluetoch. to give you connectivity via Wi-Fi.
In this code, the esp32 module is connected to my home
router and I can do it with my pc. I don't know how I should do
to flow as it should be... with the repeater host, it connects, but the protocol is
not well established so that they understand each other...
 WiFi Web Server
 If the IP address of your shield is yourAddress:
 http://yourAddress/H turns the LED on
 http://yourAddress/L turns it off
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the Wifi.begin() call accordingly.
 Circuit:
 * WiFi shield attached
 created for arduino 25 Nov 2012
 by Tom Igoe
ported for sparkfun esp32
31.01.2017 by Jan Hendrik Berlin
#include <WiFi.h>
const char* ssid     = "printer 3d";
const char* password = "123456";
WiFiServer server(80);
void setup()
    Serial.begin(115200);
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    server.begin();
int value = 0;
void loop(){
 WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
   // Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {
       if (Serial.available()) {
       client.print(Serial.read());
        // Serial.write("hola");
      // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        //char c = client.read();             // read a byte, then
       Serial.write(client.read());
    // close the connection:
    client.stop();
   // Serial.println("Client Disconnected.");
  • This works with TP/IP connection or Telnet connection in host. Enter ip and port required.
    It is essential that the esp32 just puts the data through to firmware and returns results 1:1. No interference no protocol addition especially no web browser protocol (http) on that port. Any other communication with tcp/ip is not supported.
  • edited May 2022
    Hello, I have tried in different ways and I cannot establish the connection correctly via wifi-esp32. any ideas?
    When it connects, I can see that repetier-host correctly sends the data to the esp32-wifi, I see it through the serial port of the Esp32. Photo 1
    https://ibb.co/Csk94LM
    When it sent data over serial , relayed over wifi, the repetier-host captured correctly. photo 2
    … I do not know what I'm doing wrong. Help -___-   https://ibb.co/Ry7M83L
    #include <WiFi.h>
    const char* ssid     = "wifi";
    WiFiServer server(8080);
    void setup()
       // pinMode(5, OUTPUT);      // set the LED pin mode
        delay(10);
        Serial.println();
        Serial.println();
            delay(500);
            Serial.print(".");
        Serial.println("");
        server.begin();
    size_t len=0;
    size_t len2=0;
    byte sbuf[128];
    byte sbuf2[128];
    void loop(){
        while (client.connected()) {            // loop while the client's connected
            len = client.available();
             client.readBytes(sbuf, len);
             Serial.write(sbuf,len);
            len2 = Serial.available();
            Serial.readBytes(sbuf2, len2);
            client.write(sbuf2, len2);
       client.stop();
  • What does the "WiFi.h" library d? http or just tcp connection? As said it must be a plain tcp connection and port 8080 sounds like http. Also the loop looks much like it just answers a http request, that is not the kind of connection you need for communication with host/server.
  • edited May 2022
    EUREKA WORKS!!
    I ONLY NEEDED A SECOND SERIAL PORT. IT SEEMS TO BE IN COMPLICT WITH DEFAUT.
    #include <WiFi.h>
    const char* ssid = "777";
    const char* password = "777";
    #define RXD2 16
    #define TXD2 17
    void setup()
    Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
    delay(10);
    Serial.println();
    Serial.println();
    delay(500);
    Serial.print(".");
    Serial.println("");
    server.begin();
    size_t len=0;
    size_t len2=0;
    byte sbuf[128];
    byte sbuf2[128];
    void loop(){
    Serial2.write(sbuf,len);
    if (Serial2.available()) {
    len2 = Serial2.available();
    Serial2.readBytes(sbuf2, len2);
    client.stop();
  • Great it works. Just do not understand what the first serial is used for. Client talks with host/server and Serial2 with printer firmware. But what is serial used for? Surely not firmware as it is not correct format. Looks like some monitoring serial you could connect with for debugging, but otherwise not required.
