how to connect the Esp32 wifi to the connect ramps 1.4 ?
hello, I have connected the ESP32-38 PIN, to the ramps 1.4 instead of the bluetoch. to give you connectivity via Wi-Fi. In this code, the esp32 module is connected to my home
router and I can do it with my pc. I don't know how I should do
to flow as it should be... with the repeater host, it connects, but the protocol is
not well established so that they understand each other...
WiFi Web Server
If the IP address of your shield is yourAddress:
http://yourAddress/H turns the LED on
http://yourAddress/L turns it off
This example is written for a network using WPA encryption. For
WEP or WPA, change the Wifi.begin() call accordingly.
Circuit:
* WiFi shield attached
created for arduino 25 Nov 2012
by Tom Igoe
ported for sparkfun esp32
31.01.2017 by Jan Hendrik Berlin
#include <WiFi.h>
const char* ssid = "printer 3d";
const char* password = "123456";
WiFiServer server(80);
void setup()
Serial.begin(115200);
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
server.begin();
int value = 0;
void loop(){
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
// Serial.println("New Client."); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) {
if (Serial.available()) {
client.print(Serial.read());
// Serial.write("hola");
// loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
//char c = client.read(); // read a byte, then
Serial.write(client.read());
// close the connection:
client.stop();
// Serial.println("Client Disconnected.");
It is essential that the esp32 just puts the data through to firmware and returns results 1:1. No interference no protocol addition especially no web browser protocol (http) on that port. Any other communication with tcp/ip is not supported.
const char* ssid = "wifi";
WiFiServer server(8080);
void setup()
// pinMode(5, OUTPUT); // set the LED pin mode
delay(10);
Serial.println();
Serial.println();
delay(500);
Serial.print(".");
Serial.println("");
server.begin();
size_t len=0;
size_t len2=0;
byte sbuf[128];
byte sbuf2[128];
void loop(){
while (client.connected()) { // loop while the client's connected
len = client.available();
client.readBytes(sbuf, len);
Serial.write(sbuf,len);
len2 = Serial.available();
Serial.readBytes(sbuf2, len2);
client.write(sbuf2, len2);
client.stop();
