Yes, as long as you do not enter a license key it behaves like the free version with some reduced functions. But these are not time limited and everything you need to print gcode.
What display do you mean? If you have a lcd on pi and use the optimized printer frontend, that requires in deed a pro license. If you just call on your normal pc/iPad/phone http://ip:3344 then you see a ui that does not require a license. Only problem is that it will not work good on a pi browser since it uses quite some ram.
How can we enter the license key once when we have installed the repeater server on the raspberry pi zero W?
I'll buy a license
Thanks for this great software
Thank you
Martin
https://www.repetier-server.com/live-demo/
and use the demo server to see what pro offers and how it looks.
