Repetier server Raspberry license
Is there a free license for the Repetier server on Raspberry ?
Franck
  • Yes, as long as you do not enter a license key it behaves like the free version with some reduced functions. But these are not time limited and everything you need to print gcode.
  • Thanks but I don't understand because I have a Qrcode on the screen and I can't do anything. I have to enter a valid license number to go on ...
  • What display do you mean? If you have a lcd on pi and use the optimized printer frontend, that requires in deed a pro license. If you just call on your normal pc/iPad/phone http://ip:3344 then you see a ui that does not require a license. Only problem is that it will not work good on a pi browser since it uses quite some ram.
  • Ok ,now I understand. I have a LCD screen for my Raspberry.
    I'll buy a license ;)
    Thanks for this great software ;)
  • Hello, is possible to try demo?
    Thank you
    Martin
  • After first installation it offers a 14 day trial. You can also check our demo page
    https://www.repetier-server.com/live-demo/
    and use the demo server to see what pro offers and how it looks.
  • Actual I have a  free version on my raspberry pi installed. Is it then popssible to change it in a licensed Version without a new installation?
    Thanks a lot
    manylomy
  • Yes. Pro license is same executeable, just in registration window you activate it as pro to get all features.
    How can we enter the license key once when we have installed the repeater server on the raspberry pi zero W?
  • Just open the regular web GUI and select in main menu "Register" and enter it. Requires active internet configuration.
