Pause function
When I print from SD 2 functions appear in the CD-menu (my menu is german, that is my translation to english!):
Print Pause
Print Stop
When I press the pause function the printer moves to a point and crashes in the bed.
I do not know where to define the gcode code for the pause function?
(Repetier 0.91 / own made tripod)
Print Pause
Print Stop
UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_sd_pause, UI_TEXT_PAUSE_PRINT, UI_ACTION_SD_PAUSE, MENU_MODE_SD_PRINTING, MENU_MODE_SD_PAUSED)
but I don't come further what to do ...
I wrote to Pause Start Script: G90\nG1 Z300\nG1 X-99 Y56
and Pause end script: empty
With pause it stops at the described position.
But with Print Continue it does not start at the position before the Pause!
Probably my end script is missing?!
What have you added?
1.If I erase the Pause start script - then the tripod goes to a new position, Z- same as point of pause Y=135 X=0
(I have no idea whrere those values came from!!)
2. If I press pause on Z=0 then the nozzle moves to Y=135/X=0/Z=0 - but on its way it comes under Z=0! The movement seems not follow the tripod movement. It is not linear, it is more like an arc (very obvious to see). So the nozzles crashes into the bed (I have it on spings, so not a real issue) and finally after all axes reach the final position, the nozzle arrives on Y135/X0.
Maybe there is a bug for tripod!
3.) The deceleration of the axes are very hard, not as usual. It looks like the acceleration values are not considered.
@Sonic300077: do you have a xyz printer or a tripod?
I think that is a question for Repetier-Support
I admire your source knowledge!!
Thats over my programme horizont ....
Can or Should I include the code somewhere?
1) ok
2.) Is that the repeat time?
In the configuration are 2 fields: "Repeat time after: 500ms" and "Reduce repeat time by: 50ms"
What values would you recommend?
3) I think the travel values (speed/acceleration) will also be used at G28 (home position). But at G28 the movements are smoother. So where should I define the travel acceleration?
Thanks for your help!
3) Hmm but I print with the current values all the time and never get so harsh stops ...
so point 2) is gone!
3) I changed in SDCARD.cpp the maxFeedrate to maxFeedrate/2
then back to them! how to make that distance that I stretched filament
deleted! but it turns out that I put filament comes back priter Returns
the filament back at that distance I put while I filament
