Repetier firmware V1.3
Hello,
I just mounted a new 3D Printer Prusa i3, acrylic frame :
P802-D
Zonestar
Firmware_name:repetier_V1.3
Protocol_version:1.0
Machine_type:Mendel
Exstruder_count:1
Repetier_protocol:2
Display type:QC2004A
Where can i find more information regarding this new version of your firmware, copy and save it, as well as the manual for new LCD display with five buttons ?
Regards,
Paul LINDEN
This is my machine.
Regards,
Paul LINDEN
Hereafter the answer i just received from the seller of my printer :
"Dear Paul.
Regards,
Paul LINDEN
for exam:
#define FEATURE_CONTROLLER 2
I found this picture. At the bottom you'll find in clear text "repetier v0.91" and "http://www.repetier.com/download/ !
If you have possibility to translate from chinese, what does this mean ?
Regards,
Paul LINDEN
Regards,
Paul LINDEN
The seller has given me the HEX firmware which seems right (same strings as what can be seen on the LCD menu) and the source code (compilable with Arduino 1.0.4) which is not the good one since the keys scan routine using an analog input does NOT exist. If someone want them, please, mailpost me, I'll give you the link. I think I will end up sharing publicly the files because they are GPL anyway. The only problem is they are not yet validated.
I wrote back to the seller because I need the source code to add an inductive sensor for autolevelling. He promised to "see with the engineer", but no news, no nothing, for some weeks now !
I'm very interested to your firmwaresource as i'm trying to decompile the original hexfile of my melziboard...Please send it to me : tyyeul@gmail.com. I'll be very grateful !
Regards,
P.Linden
I have the same model (v1.4/black), and ...5keys.rar works fine. Unfortunately I couldn't bacup original firmware, since bootloader is not installed on my board and flash lockbits are set.
> i can heating heatbed but 80C to 95C jumping.
Yup, same here. It seems that thermistor table is faulty. After flashing firmware from above post problem resolved itself, but bed can't heat over 80-90*C anyway. I've measured all resistances and voltage drops, and it looks like my bed have only about 70-80W of heating power. So I'm going to replace it with 500W/230V silicone heater.
ok thx
this is machine in no included bootloader?
not enough flash or repetier programs cant work?
i can see config..h axelsp and kaworu but axelsp's config in epcos temp sensor
you have temp..table how sensor can be sure?
I can programming bootloader or only firmware burning isp?
thx i have hesine....
but i have stk200 :-( and dead avr dragon ;-(
cant locked isp programming?
i need usbasp?
i can pushing scetch/ verifyng/compiling but a not see binary this is normaly?
