repetier host issues
I have been using repetier host for quite a while now, I am using version 2.1.6, it has developed two issues I cannot solve. When I start a print, I home all axis, host then retracts the bed 30 mm while everything comes up to temp. When the print starts host does not return the bed to the home position thereby extruding filament into thin air. The second issue is that I cannot change the bed temp, I was set at 97c for abs but now I want to use pla and drop the temp to 70c. I set host for 70c but when the print starts host heats to 97c reliably. I have set all settings in the printer config but host is ignoring my changes
