Cura directly to Repetier PI Server
How G code be loaded directly to Repetier Pi server from Cura?
I installed RepetierIntegration and can manage printers/Connect Repetier and enter API Key.   Error message "Repetier printer name has not been selected...." but there is not a name to select?  There is a place to enter Instance Name but what should one enter?
Cura version 4.12.1.  Repetier server Pro 1.0.4
  • We are not author of that plugin, so can not say what is going wrong there.
    You might use  Repetier-Server Monitor instead for uploading files. That way you just save from cure to the watched folder.
  • Thank you.  Works perfectly first time.
