Cura directly to Repetier PI Server
How G code be loaded directly to Repetier Pi server from Cura?
I installed RepetierIntegration and can manage printers/Connect Repetier and enter API Key. Error message "Repetier printer name has not been selected...." but there is not a name to select? There is a place to enter Instance Name but what should one enter?
Cura version 4.12.1. Repetier server Pro 1.0.4
You might use Repetier-Server Monitor instead for uploading files. That way you just save from cure to the watched folder.
