Extruder motor vibrates but does not move.
Hello!
I have a ramps 1.4 with arduino mega 2560. Everything works with Marlin firmware.
With Repetier (versions .91 and .92), the extruder motor just makes a buzzing sound, vibrates (I can feel this vibration even in the filament) and appears to be stuck in place.
The extruder is heated, moving the axis also works fine, homing, etc.
Already tried reversing wiring, tested wiring, replaced stepper driver, tested with another motor, pretty much everything.
I have another control board (MKS-BASE), that runs fine in the same printer with Repetier Firmware.
Anybody having a similar issue?
For some reason, when I set up my steps per mm in the firmware configuration tool, 632.271 became 632271!
Fixed it in the EEPROM, and now everything works!
